If I view a table in ArcCatalog the Name column has values that are not null. There is no domain associated with this column.
If I query the same table in SQL the same values display as null.
I've noticed this with multiple tables and the only thing that seems similar between them is that the null value columns come after the Shape column. Is the enterprise geodatabase somehow storing values that have been added post import differently?
The SQL query is simply
SELECT *
FROM gis.dbo.REGIONS
Every column after shape is null.
