Hello, I was wondering if I could get some help with this problem.
Currently I'm using this line of code to select point features inside of a polygon.
MapView.Active.SelectFeatures(polygon, SelectionCombinationMethod.Add, true, false);
However I noticed it is not very.. accurate? the description for this method is that it selects features that intersect a geometry, however clearly that's not whats happening as the points are outside of the polygon. What would be a functioning equivalent to the geoprocessing tool Select by Location? As the SelectFeatures method is unclear as to what it actually does.
Any help would be appreciated.
The solution I found was to use a SpatialQueryFilter (below)
SpatialQueryFilter sqf = new SpatialQueryFilter { FilterGeometry = polygon, SpatialRelationship = SpatialRelationship.Contains };
[pointlayer].Select(sqf);
Instead of MapView.Active.SelectFeatures(polygon), which doesn't work properly.
