I’ll need to Create a feature using the current template while modifying some values in an active template (i.e. setting a common note or specific Asset ID value "before" creating a feature with the template, other default values in the template are Ok). I want to avoid two-steps process - create a feature with the template and then modify it in second Edit operation.
var myTemplate = ArcGIS.Desktop.Editing.Templates.EditingTemplate.Current;
var myGeometry = _geometry;
var op = new ArcGIS.Desktop.Editing.EditOperation();
op.Name = "Create my feature";
// NEED TO UPDATE some of myTemplate default attributes here
op.Create(myTemplate, myGeometry); op.Execute();
When creating a feature in ArcGIS Pro, one can open an active template pane to modify default values for features to be created with this template. Can this be done via API ?
I tried to leverage myTemplate.Inspector to get the Inspector that should contain the associated template values (as per the doc) but it is set to null . I guess I do not know how to use the API in this case. Any advise, code snippets will be appreciated. Thanks
