Good day!
I am working on a workbook in Insights for ArcGIS and have been running into an issue with a map that I created with a filter applied suddenly breaking. The workflow and issue is as follows:
- I add a hosted feature layer (polygon, 40 features) from my organization.
- I also added an .xlsx file from my local machine.
- I create a relationship between the two items. (All join)
- Using two fields from the newly created table, I create a map that shows sum of personnel assignment by zone.
- In layer options, I change the symbol type from Counts and Amounts (Size) to Counts and Amounts (Color). I leave the default Natural Breaks and 5 classes. I also change the color scheme.
- I then apply a filter using a field from the new joined table. The field is "SHIFT" with four options: "Select all", "Days", "Evenings", and "Midnights" I choose one. (Issue occurs for all)
- The map now successfully displays personnel assignment per zone on a given shift.
- I start to work on something else in the workbook OR I save it and exit.
- I return and suddenly there are no features on the map, just a small caution mark in the bottom left corner stating that "We couldn't display all features"
- Rage.
If I click the layer options button on the top right, the entire card breaks and gives me the "Something went Wrong." screen. If I reapply the filter, the card continues to work until it suddenly decides to not.
Any help would be much appreciated! Thanks!
Kevin
