I have a query in a loop. I have added .then to the end of the queryTask (see below) to add a graphic for each result upon resolution, but I want to set the extent based on all the results. How do I do this?
queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>_onQueryResult<SPAN class="punctuation token">,</SPAN> symbolColor<SPAN class="punctuation token">,</SPAN> include<SPAN class="punctuation token">,</SPAN> def<SPAN class="punctuation token">,</SPAN> i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
def<SPAN class="punctuation token">.</SPAN><SPAN class="token function">resolve</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>state<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'failure'</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> error<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword
