Has anyone had luck using the prepare_data method with data not exported from the Export Training Data tool in ArcGIS Pro? The documentation suggests prepare_data will take PASCAL_VOC_rectangles from other sources.
I tried doing the following:
prep <SPAN class="operator token">=</SPAN> prepare_data<SPAN class="punctuation token">(</SPAN>path<SPAN class="punctuation token">,</SPAN>dataset_type<SPAN class="operator token">=</SPAN><SPAN class="string token">'PASCAL_VOC_rectangles'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
but keep getting:
Please check your dataset. 26 images dont have the corresponding label files.<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
Per the 1.7 release of the Python API, the prepare_data should be able to take XMLs produced from LabelImg. This has not been working for me.
The path variable is the path to my folder containing two subfolders, labels and images. Labels contains my XMLs and the images contains (you guessed it) my TIFs. I have tried to mimic how these folders are formatted like in the Export Training Data tool does, and I still cannot get it to work. Now I know the the Export Training Data tool creates some extra files beyond these folders, like .emd, map.txt, something else, but even when I delete these files, and run the prepare_data on the folder created from ArcGIS Pro, it works (but it doesn't work for my images and XMLs used through LabelImg).
Some stuff below for illustration purposes:
Folder structure (identical in both)
XML from Export Training Data
<SPAN class="prolog token"><?xml version="1.0"?></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>annotation</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>filename</SPAN><SPAN class="punctuation token">></SPAN></SPAN>000000001.tif<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>filename</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>source</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>annotation</SPAN><SPAN class="punctuation token">></SPAN></SPAN>ArcGIS Pro 2.1<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>annotation</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>source</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>size</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>width</SPAN><SPAN class="punctuation token">></SPAN></SPAN>256<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>width</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>height</SPAN><SPAN class="punctuation token">></SPAN></SPAN>256<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>height</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>depth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>3<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>depth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>size</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>object</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>bndbox</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>42.44<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>128.19<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>160.13<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>226.85<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>bndbox</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>object</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>XML created through LabelImg (1st one I edited to try and match, 2nd one is what it produces raw).
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>filename</SPAN><SPAN class="punctuation token">></SPAN></SPAN>outtif_7500_2500.tif<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>filename</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>width</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2500<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>width</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>height</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2500<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>height</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>car<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1798<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1724<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1818<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1779<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1305<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1502<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1361<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1525<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1720<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1418<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1746<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1477<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1084<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1092<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1145<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1115<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1670<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>727<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1737<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>743<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1902<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>869<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1963<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>884<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>folder</SPAN><SPAN class="punctuation token">></SPAN></SPAN>images<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>folder</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>filename</SPAN><SPAN class="punctuation token">></SPAN></SPAN>out.tif_2500_5000.tif<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>filename</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>path</SPAN><SPAN class="punctuation token">></SPAN></SPAN>C:\Users\me\Documents\ArcGIS Pro 2.3\DeepLearning\SPLIT\images\out.tif_2500_5000.tif<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>path</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>database</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Unknown<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>database</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>segmented</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>segmented</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>pose</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Unspecified<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>pose</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>truncated</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>truncated</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>difficult</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>difficult</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1446<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>523<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1493<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>557<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1468<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>605<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1537<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>651<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1494<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>460<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1543<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>504<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1336<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>102<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1390<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>xmax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>141<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ymax</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
David Vitale
Vinay Viswambharan
Rohit Singh
Atma Mani
John Yaist
