Hi
I'm starting to develop som geoprocessing tools in ArcGIS Pro using some third party python modules, but even with the simpliest of tools it fails to run from Portal
Sample code
import arcpy
import openpyxl
class Toolbox(object):
def __init__(self):
"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""
self.label = "Toolbox"
self.alias = ""
# List of tool classes associated with this toolbox
self.tools = [Tool]
class Tool(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "Tool"
self.description = ""
self.canRunInBackground = False
def getParameterInfo(self):
"""Define parameter definitions"""
param0 = arcpy.Parameter(
displayName="Input Features",
name="in_features",
datatype="GPString",
parameterType="Required",
direction="Input")
param0.filter.type = "ValueList"
param0.filter.list = ['test1','test2']
param1 = arcpy.Parameter(
displayName="Label",
name = "LabelTest",
parameterType="Optional",
direction="Input"
params = [param0, param1]
return params
def isLicensed(self):
"""Set whether tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
parameters[1].value = parameters[0].value
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
return
def execute(self, parameters, messages):
"""The source code of the tool."""
returnVal = parameters[0].value + ' TEST ' + parameters[1].value
arcpy.AddWarning(returnVal)
return
If I run this from Pro theres no problem and I can publish it as a webtool, no problem
But when I want to run it from portal i fails, unless I publis it without the import openpyxl line
So how do I get portal to use third party python modules like openpyxl ?
