Hi Robert, or anyone who can help,
Unzipped "LayerToggleButton" folder is copied to ...\server\apps\13\widgets folder.
But when I try to add the widget into my app, this widget is not on the list to choose from.
I did the 1st readme instruction. Not sure what and where to edit the main config.json? Can you explain more/
1. Replace the widget.js in the themes\FoldableTheme\widgets\HeaderController folder with the one I have provided in this download.
2. Manullay edit the apps main config.json to add "selected": true, to the widget.
The unzipped "LayerToggleButton" has two sub-folders "HeadController" and "LayerToggleButton" , I also tried to only put the subfolder "LayerToggleButton" under widgets, still no luck.
