Hi all,
Please bear with me, I'm relearning ArcMap after using mapinfo exclusively for the last two years.
I'm trying to work with a raster data set (attached in zip file) sourced from the USGS and having issues working with it as it is missing it's spatial reference information. The raster's metadata includes the following information:
- Map Projection Name: Lambert Azimuthal Equal Area
- longitude of projection center: -100.000000
- latitude of projection center: 45.000000
- false easting: 0.000000
- false northing: 0.000000
- Planar Coordinate Encoding Method: row and column
- coordinate representation:
- abscissa resolution: 1000.000000
- ordinate resolution: 1000.000000
- planar distance units: meters
- geodetic model:
- horizontal datum name: D Shpere ARC INFO
