I created a simple widget using my own code and want to run in WAB developer Edition.
In Widget.html file, I have a dijit/form/Select as the following:
<select class="ControlA"
data-dojo-attach-point="myfirstControl"
data-dojo-type="dijit/form/Select">
</select>
In Widget.js file, I have add some values to the 'Select'; I want to get the current displayed value using the code as the following:
alert("The current selected value is "+ this. myfirstControl.displayedValue);
But the system always indicated that it is not defined. So what if I need to get some information from my dijit/form/Select? What should I do? Thanks a lot!
