I am accessing and executing the GoToXY tool but I cannot find any methods in the api that allow me to set the default latitude and longitude. On the click of a button, I want the GoToXY control to open with preset latitude and longitude values. I thought that maybe the lat and long would be children of the wrapper but when I accessed the children property of the plugin wrapper, it returned an empty list. Uma Harano Wolfgang Kaiser
<SPAN class="keyword token">protected</SPAN> <SPAN class="keyword token">override</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">OnClick</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> commandId <SPAN class="operator token">=</SPAN> <SPAN class="string token">"esri_mapping_gotoXYControl"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> iCommand <SPAN class="operator token">=</SPAN> FrameworkApplication<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetPlugInWrapper</SPAN><SPAN class="punctuation token">(</SPAN>commandId<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> ICommand<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>iCommand <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// Let ArcGIS Pro do the work for us</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>iCommand<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CanExecute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
iCommand<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Execute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
