Can you please take a look at this snippet and let me know why I am not able to properly pass the Where Clause ('"[NAME_1]" = Ohio') in SearchCursor?
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">unique_values</SPAN><SPAN class="punctuation token">(</SPAN>table <SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>table<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN>field<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'"[NAME_1]" = Ohio'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> sorted<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
uniques <SPAN class="operator token">=</SPAN> unique_values<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">'C:\arcgis\ArcTutor\AAA\src\USA.shp'</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'NAME_2'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN
