In arcgis online i have a webmap where i did a sumamrize within of a bunch of points into polygons to give those polygons density colours based on the number of points that are within them, now I want to do the same thing but solely in python. my points are the "QFESFireStations", and my polygons are the "Drought Affected Shires; QLD". My code is below. Also, I dont get why the summary_polygons layer is optional, because the tool NEEDS two layers, so how can only one layer be required for an input??? See the links below.
For some reason when i run this below i get (AttributeError: 'Item' object has no attribute 'summarize_within')
from arcgis.geoanalytics.summarize_data import summarize_within
webmap.summarize_within(summarized_layer="QFESFireStations", output_name = "SEE_ME",
polygon_or_bin = "POLYGONS", bin_type = "SQUARE",
summary_polygons="Drought Affected Shires; QLD", sum_shape = True)
https://esri.github.io/arcgis-python-api/apidoc/html/arcgis.geoanalytics.summarize_data.html#summarize-within
Also, this is just a note I have three variable types
webmap = item
NewWebMap = MapView
usable = WebMap
I tried the samething using arcpy but also didnt work.
# https://pro.arcgis.com/en/pro-app/tool-reference/big-data-analytics/summarize-within.htm
import arcpy
drought = gis.content.get('4e73c854013a43beb258150d4be7e135')
Fire_station = gis.content.get('84fead439e2444a299d75296c365aba7')
outFS = 'SEE_ME1'
dataStore = "SEE_ME_DataStore1"
# Execute SummarizeWithin
arcpy.geoanalytics.SummarizeWithin(Fire_station, outFS, "POLYGON", None, None, drought, "ADD_SUMMARY", dataStore)
This gives the error (RuntimeError: Object: Error in executing tool)
