I have a form with a TreeView in which the user can select different maps to be loaded into ArcMap.
The issue is that if clicking outside of the form window, the last selection gets "locked up", and then it keeps selecting that no matter where you click on the screen.
I fixed it by displaying it with frm.showDialog(), but this is not a perfect scenario either.
The options are being generated by a switch like this one:
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">treeView_AfterSelect</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">object</SPAN> sender<SPAN class="punctuation token">,</SPAN> TreeViewEventArgs e<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
ClsMaps wsf2 <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>ClsMaps<SPAN class="punctuation token">)</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ClsMaps</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">switch</SPAN> <SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">.</SPAN>Node<SPAN class="punctuation token">.</SPAN>Name<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">"Option1"</SPAN><SPAN class="punctuation token">:</SPAN>
tbMessages<SPAN class="punctuation token">.</SPAN>Text <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Loading : "</SPAN> <SPAN class="operator token">+</SPAN> e<SPAN class="punctuation token">.</SPAN>Node<SPAN class="punctuation token">.</SPAN>Name<SPAN class="punctuation token">;</SPAN>
wsf2<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetMaps</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">@"Option1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"Some\Path\To\Option1_geotiff\Somewhere"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"indesOption1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"FilePath"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">"Option2"</SPAN><SPAN class="punctuation token">:</SPAN>
wsf2<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetMaps</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">@"Option2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"Some\Path\To\Option2_geotiff\Somewhere"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"indexOption2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"FilePath"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">"Option3"</SPAN><SPAN class="punctuation token">:</SPAN>
wsf2<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetMaps</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">@"Option3"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"Some\Path\To\Option3_geotiff\Somewhere"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"indexOption3"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"FilePath"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">"Option4"</SPAN><SPAN class="punctuation token">:</SPAN>
wsf2<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetMaps</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">@"Option4"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"Some\Path\To\Option4_geotiff\Somewhere"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"indexOption4"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">@"FilePath"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">default</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="token function">LoadLyrFromPath</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">.</SPAN>Node<SPAN class="punctuation token">.</SPAN>Name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
treeView<SPAN class="punctuation token">.</SPAN>SelectedNode <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The switch is a lot bigger than this, but this is the structure, no reason to post the full length of it.
The GetMaps method being called in most of the cases is this:
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">GetMaps</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">string</SPAN> strGrpLayer<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">string</SPAN> strIndexPath<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">string</SPAN> strIndexName<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">string</SPAN> strIndexColonName<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">string</SPAN> strType <SPAN class="operator token">=</SPAN> <SPAN class="string token">"TIF"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">try</SPAN>
<SPAN class="comment token">// delete grouplayer if it is already there</SPAN>
IActiveView activeView <SPAN class="operator token">=</SPAN> ArcMap<SPAN class="punctuation token">.</SPAN>Document<SPAN class="punctuation token">.</SPAN>ActiveView<SPAN class="punctuation token">;</SPAN>
IEnvelope envelope <SPAN class="operator token">=</SPAN> activeView<SPAN class="punctuation token">.</SPAN>Extent<SPAN class="punctuation token">;</SPAN>
ESRI<SPAN class="punctuation token">.</SPAN>ArcGIS<SPAN class="punctuation token">.</SPAN>Carto<SPAN class="punctuation token">.</SPAN>IMap focusMap1 <SPAN class="operator token">=</SPAN> ArcMap<SPAN class="punctuation token">.</SPAN>Document<SPAN class="punctuation token">.</SPAN>FocusMap<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">int</SPAN> layerCount1 <SPAN class="operator token">=</SPAN> focusMap1<SPAN class="punctuation token">.</SPAN>LayerCount<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">int</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> layerCount1<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN>
ILayer layer <SPAN class="operator token">=</SPAN> focusMap1<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> layerName <SPAN class="operator token">=</SPAN> layer<SPAN class="punctuation token">.</SPAN>Name<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>layer <SPAN class="keyword token">is</SPAN> IGroupLayer <SPAN class="operator token">&&</SPAN> strGrpLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Equals</SPAN><SPAN class="punctuation token">(</SPAN>layerName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
ArcMap<SPAN class="punctuation token">.</SPAN>Document<SPAN class="punctuation token">.</SPAN>FocusMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">DeleteLayer</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Open index map</SPAN>
IWorkspace ws <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
IWorkspaceFactory wsf <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>IWorkspaceFactory<SPAN class="punctuation token">)</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ShapefileWorkspaceFactory</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
ws <SPAN class="operator token">=</SPAN> wsf<SPAN class="punctuation token">.</SPAN><SPAN class="token function">OpenFromFile</SPAN><SPAN class="punctuation token">(</SPAN>strIndexPath<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
IFeatureWorkspace featureworkspace <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>IFeatureWorkspace<SPAN class="punctuation token">)</SPAN>ws<SPAN class="punctuation token">;</SPAN>
IFeatureClass fc <SPAN class="operator token">=</SPAN> featureworkspace<SPAN class="punctuation token">.</SPAN><SPAN class="token function">OpenFeatureClass</SPAN><SPAN class="punctuation token">(</SPAN>strIndexName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Create the spatial filter and set its spatial constraints.</SPAN>
ISpatialFilter spatialFilter <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialFilterClass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
spatialFilter<SPAN class="punctuation token">.</SPAN>Geometry <SPAN class="operator token">=</SPAN> envelope<SPAN class="punctuation token">;</SPAN>
spatialFilter<SPAN class="punctuation token">.</SPAN>GeometryField <SPAN class="operator token">=</SPAN> fc<SPAN class="punctuation token">.</SPAN>ShapeFieldName<SPAN class="punctuation token">;</SPAN>
spatialFilter<SPAN class="punctuation token">.</SPAN>SpatialRel <SPAN class="operator token">=</SPAN> esriSpatialRelEnum<SPAN class="punctuation token">.</SPAN>esriSpatialRelIntersects<SPAN class="punctuation token">;</SPAN>
IFeatureCursor featureCursor <SPAN class="operator token">=</SPAN> fc<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Search</SPAN><SPAN class="punctuation token">(</SPAN>spatialFilter<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
IFeature Feat1 <SPAN class="operator token">=</SPAN> featureCursor<SPAN class="punctuation token">.</SPAN><SPAN class="token function">NextFeature</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Create grouplayer</SPAN>
IGroupLayer groupLayer1 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GroupLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
groupLayer1<SPAN class="punctuation token">.</SPAN>Name <SPAN class="operator token">=</SPAN> strGrpLayer<SPAN class="punctuation token">;</SPAN>
groupLayer1<SPAN class="punctuation token">.</SPAN>Expanded <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//open a raster dataset from a file system</SPAN>
Type factoryType <SPAN class="operator token">=</SPAN> Type<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetTypeFromProgID</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"esriDataSourcesRaster.RasterWorkspaceFactory"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
IWorkspaceFactory wsFactory <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>IWorkspaceFactory<SPAN class="punctuation token">)</SPAN>Activator<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateInstance</SPAN><SPAN class="punctuation token">(</SPAN>factoryType<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">int</SPAN> intNumFeatures <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Add all raster files to grouplayer</SPAN>
<SPAN class="keyword token">while</SPAN> <SPAN class="punctuation token">(</SPAN>Feat1 <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//</SPAN>
<SPAN class="keyword token">int</SPAN> intColnr <SPAN class="operator token">=</SPAN> Feat1<SPAN class="punctuation token">.</SPAN>Fields<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FindField</SPAN><SPAN class="punctuation token">(</SPAN>strIndexColonName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> strTest <SPAN class="operator token">=</SPAN> Feat1<SPAN class="punctuation token">.</SPAN><SPAN class="token function">get_Value</SPAN><SPAN class="punctuation token">(</SPAN>intColnr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">ToString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>strTest<SPAN class="punctuation token">.</SPAN>Length <SPAN class="operator token">==</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="operator token">||</SPAN> strTest<SPAN class="punctuation token">.</SPAN>Length <SPAN class="operator token">==</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">else</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>strType <SPAN class="operator token">==</SPAN> <SPAN class="string token">"TIF"</SPAN> <SPAN class="operator token">||</SPAN> strType <SPAN class="operator token">==</SPAN> <SPAN class="string token">"AnotherStringType"</SPAN> <SPAN class="operator token">||</SPAN> strType <SPAN class="operator token">==</SPAN> <SPAN class="string token">"AThirdStringType"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">string</SPAN> strPath <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> strFileName <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>strType <SPAN class="operator token">==</SPAN> <SPAN class="string token">"TIF"</SPAN><SPAN class="punctuation token">)</SPAN>
strPath <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetDirectoryName</SPAN><SPAN class="punctuation token">(</SPAN>strTest<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
strFileName <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetFileName</SPAN><SPAN class="punctuation token">(</SPAN>strTest<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">else</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>strType <SPAN class="operator token">==</SPAN> <SPAN class="string token">"AnotherStringType"</SPAN><SPAN class="punctuation token">)</SPAN>
strPath <SPAN class="operator token">=</SPAN> <SPAN class="string token">@"Some\Path\To\Somewhere"</SPAN><SPAN class="punctuation token">;</SPAN>
strFileName <SPAN class="operator token">=</SPAN> strTest<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">else</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>strType <SPAN class="operator token">==</SPAN> <SPAN class="string token">"AThirdStringType"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>File<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Exists</SPAN><SPAN class="punctuation token">(</SPAN>strPath <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\"</SPAN> <SPAN class="operator token">+</SPAN> strFileName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
IRasterWorkspace2 rasterWS <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>IRasterWorkspace2<SPAN class="punctuation token">)</SPAN>wsFactory<SPAN class="punctuation token">.</SPAN><SPAN class="token function">OpenFromFile</SPAN><SPAN class="punctuation token">(</SPAN>strPath<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
IRasterDataset rds <SPAN class="operator token">=</SPAN> rasterWS<SPAN class="punctuation token">.</SPAN><SPAN class="token function">OpenRasterDataset</SPAN><SPAN class="punctuation token">(</SPAN>strFileName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
IRasterLayer rasterLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">RasterLayerClass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
rasterLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateFromDataset</SPAN><SPAN class="punctuation token">(</SPAN>rds<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>strGrpLayer <SPAN class="operator token">==</SPAN> <SPAN class="string token">"SomeGroupLayer"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">////show sentinel2 correct</SPAN>
RasterRGBRendererClass rasterRGBRenderer1 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">RasterRGBRendererClass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
rasterRGBRenderer1<SPAN class="punctuation token">.</SPAN>StretchType <SPAN class="operator token">=</SPAN> esriRasterStretchTypesEnum<SPAN class="punctuation token">.</SPAN>esriRasterStretch_NONE<SPAN class="punctuation token">;</SPAN>
rasterRGBRenderer1<SPAN class="punctuation token">.</SPAN>UseGamma <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
rasterRGBRenderer1<SPAN class="punctuation token">.</SPAN>RedBandIndex <SPAN class="operator token">=</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">;</SPAN>
rasterRGBRenderer1<SPAN class="punctuation token">.</SPAN>GreenBandIndex <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
rasterRGBRenderer1<SPAN class="punctuation token">.</SPAN>BlueBandIndex <SPAN class="operator token">=</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// laver array af doubles med 3 pladser, og tilføjer 1 til index 0, 2 til index 1 og 1 til index 2</SPAN>
<SPAN class="keyword token">double</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN> gammas <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">double</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
gammas<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">;</SPAN>
gammas<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">;</SPAN>
gammas<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">;</SPAN>
rasterRGBRenderer1<SPAN class="punctuation token">.</SPAN>GammaValue <SPAN class="operator token">=</SPAN> gammas<SPAN class="punctuation token">;</SPAN>
rasterLayer<SPAN class="punctuation token">.</SPAN>Renderer <SPAN class="operator token">=</SPAN> rasterRGBRenderer1<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//add raster to grouplayer</SPAN>
groupLayer1<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN>rasterLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
MessageBox<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Denne fil kan ikke findes : "</SPAN> <SPAN class="operator token">+</SPAN> strPath <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\"</SPAN> <SPAN class="operator token">+</SPAN> strFileName <SPAN class="operator token">+</SPAN> System<SPAN class="punctuation token">.</SPAN>Environment<SPAN class="punctuation token">.</SPAN>NewLine <SPAN class="operator token">+</SPAN> <SPAN class="string token">" Kontakt en skriftklog og han kan hjælpe dig. Husk kontanter !"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">else</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>strType <SPAN class="operator token">==</SPAN> <SPAN class="string token">"SHP"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//strTest = System.IO.Directory.GetParent(strIndexPath).ToString() + "\\" + strTest;</SPAN>
<SPAN class="keyword token">string</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN> filePaths <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Directory<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetFiles</SPAN><SPAN class="punctuation token">(</SPAN>strTest<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*.shp"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">int</SPAN> i2 <SPAN class="operator token">=</SPAN> filePaths<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Count</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">int</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><=</SPAN> i2 <SPAN class="operator token">-</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">string</SPAN> strPath2 <SPAN class="operator token">=</SPAN> filePaths<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> strPath <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetDirectoryName</SPAN><SPAN class="punctuation token">(</SPAN>strPath2<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> strFileName <SPAN class="operator token">=</SPAN> System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>Path<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetFileName</SPAN><SPAN class="punctuation token">(</SPAN>strPath2<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
IWorkspaceFactory workspaceFactory <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ShapefileWorkspaceFactoryClass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
IFeatureWorkspace featureWorkspace <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>IFeatureWorkspace<SPAN class="punctuation token">)</SPAN>
workspaceFactory<SPAN class="punctuation token">.</SPAN><SPAN class="token function">OpenFromFile</SPAN><SPAN class="punctuation token">(</SPAN>strPath<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Create a new FeatureLayer and assign a shapefile to it</SPAN>
IFeatureLayer featureLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayerClass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
featureLayer<SPAN class="punctuation token">.</SPAN>FeatureClass <SPAN class="operator token">=</SPAN> featureWorkspace<SPAN class="punctuation token">.</SPAN><SPAN class="token function">OpenFeatureClass</SPAN><SPAN class="punctuation token">(</SPAN>strFileName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
ILayer layer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>ILayer<SPAN class="punctuation token">)</SPAN>featureLayer<SPAN class="punctuation token">;</SPAN>
layer<SPAN class="punctuation token">.</SPAN>Name <SPAN class="operator token">=</SPAN> featureLayer<SPAN class="punctuation token">.</SPAN>FeatureClass<SPAN class="punctuation token">.</SPAN>AliasName<SPAN class="punctuation token">;</SPAN>
groupLayer1<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
intNumFeatures <SPAN class="operator token">=</SPAN> intNumFeatures <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>intNumFeatures <SPAN class="operator token">==</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> varResultat <SPAN class="operator token">=</SPAN> MessageBox<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">@"There is more then 10 images in this request. Do you want to load all images?"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Header"</SPAN><SPAN class="punctuation token">,</SPAN> MessageBoxButtons<SPAN class="punctuation token">.</SPAN>YesNo<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// If the no button was pressed ...</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>varResultat <SPAN class="operator token">==</SPAN> DialogResult<SPAN class="punctuation token">.</SPAN>No<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// cancel the closure of the form.</SPAN>
<SPAN class="comment token">//add grouplayer to arcgis</SPAN>
ArcMap<SPAN class="punctuation token">.</SPAN>Document<SPAN class="punctuation token">.</SPAN>FocusMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">AddLayer</SPAN><SPAN class="punctuation token">(</SPAN>groupLayer1<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
ArcMap<SPAN class="punctuation token">.</SPAN>Document<SPAN class="punctuation token">.</SPAN>FocusMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">MoveLayer</SPAN><SPAN class="punctuation token">(</SPAN>groupLayer1<SPAN class="punctuation token">,</SPAN> ArcMap<SPAN class="punctuation token">.</SPAN>Document<SPAN class="punctuation token">.</SPAN>FocusMap<SPAN class="punctuation token">.</SPAN>LayerCount <SPAN class="operator token">-</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">InvalidCastException</SPAN> e<SPAN class="punctuation token">)</SPAN>
MessageBox<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Show</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">.</SPAN>Message<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The method being called in the default is this:
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">LoadLyrFromPath</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">string</SPAN> strPath2<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>System<SPAN class="punctuation token">.</SPAN>IO<SPAN class="punctuation token">.</SPAN>File<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Exists</SPAN><SPAN class="punctuation token">(</SPAN>strPath2<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN>
IMap map <SPAN class="operator token">=</SPAN> activeView<SPAN class="punctuation token">.</SPAN>FocusMap<SPAN class="punctuation token">;</SPAN>
IGxLayer gxLayerCls <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GxLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
IGxFile gxFile <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>IGxFile<SPAN class="punctuation token">)</SPAN>gxLayerCls<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Set the path for where the layer file is located on disk.</SPAN>
gxFile<SPAN class="punctuation token">.</SPAN>Path <SPAN class="operator token">=</SPAN> strPath2<SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">AddLayer</SPAN><SPAN class="punctuation token">(</SPAN>gxLayerCls<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">MoveLayer</SPAN><SPAN class="punctuation token">(</SPAN>gxLayerCls<SPAN class="punctuation token">.</SPAN>Layer<SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">.</SPAN>LayerCount <SPAN class="operator token">-</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
tbMessages<SPAN class="punctuation token">.</SPAN>Text <SPAN class="operator token">=</SPAN> e<SPAN class="punctuation token">.</SPAN>Message<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
