I am trying to move some of my code from inspector to Row for the purposes of saving in RowCreate and Change Events. Is there a quick way to get a Row from an OID. I think I am missing something. For instance below, I want the first selected item from the selection set, but I get an OID and need to quickly get the ROW for it. I know I can do the lookup and get the row cursor, but is there an easier way than this to get a Row for a OID than GetRowForOID like I have below? Much like the Inspector does?
//I need to get what the user, if multiple, i need to get the first
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">static</SPAN> Task<SPAN class="operator token"><</SPAN>Row<SPAN class="operator token">></SPAN> <SPAN class="token function">GetFirstSelectedRow</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">try</SPAN>
Row selectedRow <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// get the currently selected features in the map</SPAN>
<SPAN class="keyword token">var</SPAN> selectedFeatures <SPAN class="operator token">=</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetSelection</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>selectedFeatures<SPAN class="punctuation token">.</SPAN>Count <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// get the first layer and its corresponding selected feature OIDs</SPAN>
<SPAN class="keyword token">var</SPAN> firstSelectionSet <SPAN class="operator token">=</SPAN> selectedFeatures<SPAN class="punctuation token">.</SPAN><SPAN class="token function">First</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// load the selected features into the inspector using a list of object IDs</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>firstSelectionSet<SPAN class="punctuation token">.</SPAN>Value<SPAN class="punctuation token">.</SPAN>Count <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
selectedRow <SPAN class="operator token">=</SPAN> <SPAN class="token function">GetRowForOID</SPAN><SPAN class="punctuation token">(</SPAN>firstSelectionSet<SPAN class="punctuation token">.</SPAN>Key <SPAN class="keyword token">as</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN> firstSelectionSet<SPAN class="punctuation token">.</SPAN>Value<SPAN class="punctuation token">.</SPAN><SPAN class="token function">First</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">return</SPAN> selectedRow<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">Exception</SPAN> e<SPAN class="punctuation token">)</SPAN>
LogWriter<SPAN class="punctuation token">.</SPAN><SPAN class="token function">LogError</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"FeatureServiceManagement - getFirstSelectedItem"</SPAN><SPAN class="punctuation token">,</SPAN> e<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN><SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">static</SPAN> Row <SPAN class="token function">GetRowForOID</SPAN><SPAN class="punctuation token">(</SPAN>FeatureLayer inFeatureLayer<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">long</SPAN> inOID<SPAN class="punctuation token">)</SPAN>
Row ReturnRow <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>inFeatureLayer <SPAN class="operator token">==</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">string</SPAN> OidFieldName <SPAN class="operator token">=</SPAN> inFeatureLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetTable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetDefinition</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetObjectIDField</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
QueryFilter qf <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryFilter</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
WhereClause <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">string</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">Format</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"{0} = {1}"</SPAN><SPAN class="punctuation token">,</SPAN> OidFieldName<SPAN class="punctuation token">,</SPAN> inOID<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// apply the query filter to the feature layer in question</SPAN>
RowCursor rowCursorSearch <SPAN class="operator token">=</SPAN> inFeatureLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Search</SPAN><SPAN class="punctuation token">(</SPAN>qf<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>rowCursorSearch <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN> <SPAN class="operator token">&&</SPAN> rowCursorSearch<SPAN class="punctuation token">.</SPAN><SPAN class="token function">MoveNext</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>rowCursorSearch<SPAN class="punctuation token">.</SPAN>Current <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN>
ReturnRow <SPAN class="operator token">=</SPAN> rowCursorSearch<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> ReturnRow<SPAN class="punctuation token">;</SPAN>
LogWriter<SPAN class="punctuation token">.</SPAN><SPAN class="token function">LogError</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"FeatureServiceManagement - GetRowForOID"</SPAN><SPAN class="punctuation token">,</SPAN> e<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
