I've seen that using tools from Attribute Assistant in Web App Builder isn't supported, so I'd like to find another solution. The Intersect method of Attribute Assistant is really what I need to replicate. All methods - Attribute Assistant | ArcGIS Solutions . It copies a value from an intersecting feature in the specified layer.
I want to use an editor tool to create new points on the map, and an attribute field populated with a corresponding value from an intersecting polygon. Example: Map displays Congressional Districts and I would like users to create new Projects (points) that get auto-populated with the Congressional District value, for which they are placed.
