Hello Friends,
I am working on understanding the Small Stormwater Solution as deployed using the standard Solution Deployment Add-In to Pro. There are several layers in the Stormwater Network feature service, representing various asset classes: Discharge, Inlet, Manhole, Pipe, etc, etc. Every one of those layers contains a field "ownedby" whose value is a coded domain:
- 1="Our Agency"
- 2="Private"
- 100="Other"
A similar domain is used for the "maintby" field
I want to change "Our Agency" to the localized name. For the hosted feature service deployed via the Solution Deployment plug-in, I can do this one layer and field at a time using "Configuration" step.. I can also use the web interface with ArcGIS On-Line. Both of those methods are one field at a time, one layer at a time. I was really hoping to be able to change the domain for all layers in one go -- to ensure they are all the same, but I also would like to modify other domains that are re-used across layers (pipe
