I have a geoprocessing model that rebuilds tile caches on a set of map services. Right now, the map services are defined by creating a multivalue MapServer variable.
This geoprocessing model will run against a development environment and a production environment, so obviously I don't want to hard-code the map services. I'd like for the user to specify a server connection, and then my model can "Select" the map services from the given server connection. The "Select Data" utility does this for folders, geodatabase, etc., but it doesn't seem for server connections. Is there another way to accomplish this?
