Can I use the Edit widget in WAB 1.2 (or 1.3) to edit the points in a feature service that is included in the Local Layer widget? When I try to configure the Edit widget it says "No editable feature layers are available".
The Local Layer widget appears to work fine as the features show in the map and the layers show up in the Layer List, Legend and Attribute Table. Do I need to add some code to the Edit widget's config.js to get it to recognize the editable feature layer from the Local Layer widget?
