Existing Windows 10 Pro for Workstations build 18383.900 machine with ArcGIS Desktop 10.7.1 concurrent license.
User logs in, opens ArcMap, goes to file/open to navigate to mxd file but file not visible.
Can see mxd file using Windows Explorer.
Using an open mxd file uses "Add Data" to navigate to shp file but file not visible.
Can see shp file using Windows Explorer.
In Windows Explorer files visible but shx file appears to be associated with Arcobat PDF for opening. Unable to change thru "Properties" or by double clicking and using Windows "How do you want to open this file" pop up menu..
When logged in as Windows Administrator these problems do not exist. Thus I presume is a Windows/ESRI permission issue.
Any ideas on resolution of problem?
Mike
