I am currently using the ClusterLayer.js file to create clustered points as in the example here. I am very happy with the results within a the JavaScript Api, but I am now trying to use it within a custom widget in the Web AppBuilder. It works almost perfectly except for one problem, the popup window closes on its own within about a second of opening it. I can't find any errors and have done everything I can think of to single out the issue with no luck. Has anyone experienced something similar before?
I was thinking that potentially there was an issue with between the infowindow popup and the PopupTemplate that is used in the demo, but I tried using the InfoWindow popup instead, but that didn't fix it either.
