Can I modify the Situation Awareness widget in Web AppBuilder Developer to take a negative buffer value? or maybe an option to do an inside buffer vs. outside buffer or both if entering a positive buffer value?
I am looking for a solution to do a negative buffer on a land parcel polygon to show a 12 foot setback line for constructing structures. A structure can't be closer than 12 feet to the property line. I currently use both the Situation Awareness widget and Developer version of Web AppBuilder. If the widget could take a negative value, it would be an easy way to show the setback so a line could be sketched over it with a drawing widget.
