Hello,I am trying to update Map Document Properties, but am struggling with the syntax for a carriage return/ line feed in the description property.If I use the Python window I can retrieve the description property and it looks something like this:>>> mxd.description
u'Test Line 1Test Line 2'
If I set the description property with the Python window with the following string:>>> mxd.description='New Line 1New Line 2'
It works as expected.However, if I try to specify that same string via a script parameter it adds an extra '\' and looks like:u'Test Line 1\\r\\nTest Line 2'
Any ideas/suggestions would be greatly appreciated.Thanks!Warren M
