I am noticing some very unusual behavior when running spatial overlays with the 2017 Business Analyst demographic data. It’s only the 2017 data - - I can run the exact same process on the 2016 data and it runs fine.
Here’s the scenario: I am using the Spatial Overlay tool in the Business Analyst toolbox to get demographic data for a set of rings. The rings are a set of various buffer distances around a single point, so they all have the same center point. The input layer is from the new 2017 demographics data (Business Analyst\\US_2017\\Data\\Demographic Data\\BlockGroups_bg.bds). When I run the tool on the set of rings, some fields are returning the same value for every single ring (specifically income fields). Other fields (such as ethnicity) are coming through as expected with different values for each ring. I ran each ring separately and it appears that all of the rings are getting the field value of the last ring that is processed. Running each ring separately gives distinct values, but running them all together gives them all the same value. Again, it’s not happening for all of the demographic fields.
Has anyone noticed this? I’m about to submit a ticket to Esri but wanted to reach out to the forum first.
Thanks in advance,
Stephanie
