We're creating an Arc Pro extension that allows users to create database connections to various file types, including GDB and SDE. Below is the code used to create a Geodatabase object out of an SDE connection. This works most of the time.
However, there is a case when this does not work, and ArcGIS Pro completely freezes up and eventually crashes. If I create a connection in the Catalog to a SQL database, that automatically creates an SDE. We need the SDE to access spatial data, so we take that SDE file path and use it to create a Geodatabase object using the code above.
If the "save password" option was not selected when the SQL connection was created, we get the freeze and crash. It makes sense that we would not be able to connect in this case, but wouldn't this crash be considered a bug?
