What is wrong with this syntax when using the Raster Calculator tool? (9.3)
I'm wondering what might be the correct syntax when using the ArcGIS 10 Raster Calculator tool compared to the old 9.3 Single Output Map Algebra tool?
Two screenshots are attached.
The first attachment shows what was correct when using the ArcGIS 9.3 Single Output Map Algebra tool
The second attachment shows how I tried to do the same using the ArcGIS 10 Raster Calculator tool which did not work!
What might be the correct syntax to such expression when using the Raster Calculator tool?
Thank you for the help
Best
Jamal
(Original post date 5/17/2012, edited to fix garbled formatting from old forums conversion by Curtis Price 5/18/2015)
