Hi can you look at my survey i created in Survey123.
I have published the Survey, i need to ask for help to retro edit and go back and split a segment of the survey into 2 groups in order to direct the submitter to a: "you answered no now answer" or
"you answered yes" this prompts the submitter to go in two different directions for two questions but then return back to the same set of questions, I have tried to set a rule for this multiple yes choices(3) or one no choice. I can only set the rule to "you answered no" brings up two questions back to back the submitter must answer to if they have selected no. That's perfect. The problem is when I set a rule for the three additional selections that all require the submitter to bypass the two " you selected no" questions, and be
