Where am I going wrong here.
countiesFeatureClass <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"E:/ArcGISProjects/CountySelection/adminjk_NWTL@Rack30.sde/Counties_1_Dissolved"</SPAN>
queryCounties <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>countiesFeatureClass<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'NEW_SELECTION'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'"FIPS2"=3 OR "FIPS2"=12'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Write the selected features to a new featureclass</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CopyFeatures_management<SPAN class="punctuation token">(</SPAN>queryCounties<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'countiesSelected'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
File "E:\ArcGISProjects\CountySelection\Python\Update_v4.py", line 32, in <module>
'"FIPS2"=3 OR "FIPS2"=12')
File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\management.py", line 7744, in SelectLayerByAttribute
raise e
ExecuteError: Failed to execute. Parameters are not valid.
The value cannot be a feature class
ERROR 000840: The value is not a Raster Layer.
ERROR 000840: The value is not a Mosaic Layer.
Failed to execute (SelectLayerByAttribute).
