Hello, I want to create a Vue app with wich will be used in desktop (electron-builder) and browser, and run some scripts with arcgis on server side, so I followed the steps:
from terminal (cmd):
vue create arcgis-app
vue add vuetify
yarn add @arcgis/webpack-plugin -D
then my vue.config.js:
const ArcGISPlugin = require("@arcgis/webpack-plugin")
module.exports = {
"transpileDependencies": [
"vuetify"
configureWebpack: {
plugins: [
new ArcGISPlugin()
}and finally running:
yarn serve
I got these compilation errors ->
98% after emitting CopyPlugin
ERROR Failed to compile with 2 errors
Module build failed (from ./node_modules/eslint-loader/index.js):
Error: No ESLint configuration found.
at Config.getLocalConfigHierarchy (......\node_modules\eslint\lib\config.js:268:39)
at Config.getConfigHierarchy (......\node_modules\eslint\lib\config.js:192:43)
at Config.getConfigVector (......\node_modules\eslint\lib\config.js:299:21)
at Config.getConfig (......\node_modules\eslint\lib\config.js:342:29)
at processText (......\node_modules\eslint\lib\cli-engine.js:181:33)
at CLIEngine.executeOnText (......\node_modules\eslint\lib\cli-engine.js:690:40)
at lint (......\node_modules\eslint-loader\index.js:278:17)
at transform (......\node_modules\eslint-loader\index.js:252:18)
at ......\node_modules\loader-fs-cache\index.js:127:18
at ReadFileContext.callback (......\node_modules\loader-fs-cache\index.js:31:14)
at FSReqCallback.readFileAfterOpen [as oncomplete] (fs.js:250:13)
You may use special comments to disable some warnings.
Use // eslint-disable-next-line to ignore the next line.
Use /* eslint-disable */ to ignore all warnings in a file.
Error: Child compilation failed:
- config.js:268 Config.getLocalConfigHierarchy
[client-vue]/[eslint]/lib/config.js:268:39
- config.js:192 Config.getConfigHierarchy
[client-vue]/[eslint]/lib/config.js:192:43
- config.js:299 Config.getConfigVector
[client-vue]/[eslint]/lib/config.js:299:21
- config.js:342 Config.getConfig
[client-vue]/[eslint]/lib/config.js:342:29
- cli-engine.js:181 processText
[client-vue]/[eslint]/lib/cli-engine.js:181:33
- cli-engine.js:690 CLIEngine.executeOnText
[client-vue]/[eslint]/lib/cli-engine.js:690:40
- index.js:278 lint
[client-vue]/[eslint-loader]/index.js:278:17
- index.js:252 transform
[client-vue]/[eslint-loader]/index.js:252:18
- index.js:127
[client-vue]/[loader-fs-cache]/index.js:127:18
- index.js:31 ReadFileContext.callback
[client-vue]/[loader-fs-cache]/index.js:31:14
- Error: No ESLint configuration found.
- compiler.js:79
[client-vue]/[html-webpack-plugin]/lib/compiler.js:79:16
- Compiler.js:343
[client-vue]/[webpack]/lib/Compiler.js:343:11
- Compiler.js:681
[client-vue]/[webpack]/lib/Compiler.js:681:15
- Hook.js:154 AsyncSeriesHook.lazyCompileHook
[client-vue]/[tapable]/lib/Hook.js:154:20
- Compiler.js:678
[client-vue]/[webpack]/lib/Compiler.js:678:31
- Compilation.js:1423
[client-vue]/[webpack]/lib/Compilation.js:1423:35
- Compilation.js:1414
[client-vue]/[webpack]/lib/Compilation.js:1414:32
- Compilation.js:1409
[client-vue]/[webpack]/lib/Compilation.js:1409:36
I got no experience with webpack neither eslint, what am I missing?
I also tried to load arcgis with esri-loader, wich works fine but only with js api 4.7. the 4.13 is out there and I don't wan't to start a project using an older version whith an loader wich is not future proof.
Thanks in advance.
