Edit (by Xander Bakker): the original question was placed at this thread: Extracting an integer from a string field but I decided to branch it to a new thread.
I have a similar situation...
For Example:
s ="POWERS 1C-23HZ"
and some are like s2 = RATTLER4C-34HZ
I would like to tell python to find the first number in each field and then split the field at the same location at the first number. so....
Field 1 = RATTLER
Field 2 = 4C-34HZ
derived from the string above: s2
I would like to use the field calculator to do this.
I know you can use this to split on the space:
!field! = s.split(' ')[0]I did this in the field calculator expression box and it works but only on the strings with a space where I need to break it.
Any help is much appreciated!
Dan A.
Message was edited by: Xander Bakker. Post branched to new Thread
