While executing the Stage Utility Network geoprocessing tool - unable to create the feature to feature class.
RROR 001904: SDE or DBMS admin user cannot create a utility network.
Failed to execute (CreateUtilityNetwork).
EXCEPTION
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\common\wrappers.py", line 90, in wrapper
return func(*args, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\gptools\tools.py", line 193, in run
service_territory_feature_class=new_svc)[0]
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\un.py", line 1779, in CreateUtilityNetwork
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\un.py", line 1776, in CreateUtilityNetwork
retval = convertArcObjectToPythonObject(gp.CreateUtilityNetwork_un(*gp_fixargs((in_feature_dataset, in_utility_network_name, service_territory_feature_class), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 001904: SDE or DBMS admin user cannot create a utility network.
Failed to execute (StageUtilityNetwork).
