I have a feature class with four fields (A1, A2, B1, B2) of type Double - each field has values as well as nulls. I want to be able to populate a second set of fields (A1A2, B1B2) with the sum of the values e.g. A1A2 = A1+A2, B1B2=B1+B2.. A simple addition using Field Calculator fails where A1 and/or A2 are nulls (which I expected). I can copy values to another field using a python expression to deal with nulls -
Prelogic Script Code
def updateValue(value):
if value == None:
return '0'
else: return value
and expression
A1A2 = (updateValue(!A1!))
(this copies A1 to A1A2 field and changes the nulls to 0 in the process.
If I change the expression to try and add two values ( i.e. A1A2 = (updateValue(!A1!)) + (updateValue(!A2!)) ), this works when both A1 and A2 are not nulls, but falls over if either or both fields are null (gives a value in A1A2 of null).
Can someone point me towards a calculator expression (or other method) of achieving this result. I want to have the expression run within a model, with the intent to have a process that I am presently doing part manually setup as a model so that a basic user (one of my managers) can run herself when requiredwithout bothering me.all the time. I should be able to set it up so that I have new fields e.g. tmpA1 and tmpA2 which are populated with the A1 and A2 values with nulls changed to 0, and then perform the addition (and will implement this if required), but to me this is a bit of a kludge and would like to have a more elegant solution. I want to maintain the original fields with their null values as these are meaningful ( null is not 0). I feel a solution should be possible within field calculator but understand that this may or may not be possible, in which case I am willing would try something else.
I have some modelbuilder skills (more like - will this work yes/no if no then try something else) without necessarily a deep understanding of what I am doing, and no real python knowledge or coding background.
