Hi all,
I'm merging together 4416 tables all within a single geodatabase, each table has two records in it. I've run this simple python script twice now, once it made it to table 343 after 7 hours, the second time 791 after 16 hours. Both times the script averaged 49 merged tables per hour which means this script would take a total of 90 hrs to run. Is there any other tool i can run that would make this run faster?
<SPAN class="keyword token">import</SPAN> arcpy
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:\\DeleteMe\\tomerge\\tables.gdb"</SPAN>
tblList <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListTables<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Merge_management<SPAN class="punctuation token">(</SPAN>tblList<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"Merged"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
