Anyone tell me why this code is returning this error? It creates the latTemp field, and I can see it after it crashes, but it will not calculate it. ERROR:<class 'arcgisscripting.ExecuteError'>: Failed to execute. Parameters are not valid. ERROR 000728: Field latSTR does not exist within table Failed to execute (CalculateField). Failed to execute (ConvertDMS2DD). Failed at Mon Feb 25 11:25:18 2013 (Elapsed Time: 9.00 seconds)
CODE:import arcpy, sys, os arcpy.env.overwriteOutput = 1 # select the feature class fc = arcpy.GetParameter(0) # select the latitude field to convert latField2 = arcpy.GetParameter(1) latField = "%s%s%s" % ('!', latField2, '!') arcpy.AddMessage("latField2 = " + str(latField2) +" latField = " +latField) lonField2 = arcpy.GetParameter(2) lonField = "%s%s%s" % ('!', lonField2, '!') arcpy.AddMessage("lonField2 = " + str(lonField2) +" lonField = " +lonField) # set lattitude output field latFieldDD = "latDD" # set longitude output field lonFieldDD = "lonDD" # set temp lattitude field, used to store lat field as string used in function latTemp = "latSTR" # set temp longitude field, used to store lon field as string used in function lonTemp = "lonSTR" latExp = "lat(%s%s%s)" % ('!',latTemp,'!') codeblockLAT = """def lat(dms): latdeg = float(dms[0:2]) latmin = float(dms[2:4]) latsec = float(dms[4:6]) latdd = latdeg + (latmin / 60) + (latsec / 3600) return latdd""" lonExp = "lon(%s%s%s)" % ('!',lonTemp,'!') codeblockLON = """def lon(dms): londeg = float(dms[0:3]) lonmin = float(dms[3:5]) lonsec = float(dms[5:7]) londd = (londeg + (lonmin / 60) + (lonsec / 3600)) * -1 return londd""" #copy the lat numeric to a string arcpy.AddField_management(fc, latTemp, "TEXT", "", "", 16) arcpy.AddField_management(fc, latFieldDD, "FLOAT", 16, 6, 16) arcpy.AddMessage("added lat fields: %s and %s" % (latTemp, latFieldDD)) #copy the lon numeric to a string arcpy.AddField_management(fc, lonTemp, "TEXT", "", "", 16) arcpy.AddField_management(fc, lonFieldDD, "FLOAT", 16, 6, 16) arcpy.AddMessage("added lon fields: %s and %s" % (lonTemp, lonFieldDD)) # do calculations arcpy.CalculateField_management(fc, latTemp, latField, "PYTHON") arcpy.CalculateField_management(fc, latFieldDD, latExp, "PYTHON", codeblockLAT) arcpy.DeleteField_management(fc, latTemp) arcpy.CalculateField_management(fc, lonTemp, lonField, "PYTHON") arcpy.CalculateField_management(fc, lonFieldDD, lonExp, "PYTHON", codeblockLON) arcpy.DeleteField_management(fc, lonTemp)
