Hi all,
I am using this sample to get the measurements for my draw toolbar. It works great. However, I would like, in addition to this to measure polylines as AreaandLength only take polygons as input. To achieve this I am using esri/tasks/LengthsParameters.
The combination of the two work but I keep getting this error: "Error: Unable to complete operation.(…)" altough it returns the right number.
Any idea?
Thanks, Alex
var geometryService = new GeometryService("http://webgisdevint1/arcgis/rest/services/Utilities/Geometry/GeometryServer");
geometryService.on("areas-and-lengths-complete", outputAreaAndLength);
var geometryServiceLength = new GeometryService("http://webgisdevint1/arcgis/rest/services/Utilities/Geometry/GeometryServer");
geometryServiceLength.on("lengths-complete", outputLength);
//Get graphics to Graphic Layer dedicated for draw
function addGraphic(evt) {
map.graphics.clear();
var geometry = evt.geometry;
var symbol = dom.byId("symbol").value;
if (symbol) {
symbol = eval(symbol);
} else {
switch (geometry.type) {
case 'point':
symbol = tb.markerSymbol;
break;
case 'polyline':
symbol = tb.lineSymbol;
break;
case 'polygon':
symbol = tb.fillSymbol;
break;
case 'freehandpolygon':
break;
default:
var areasAndLengthParams = new AreasAndLengthsParameters();
areasAndLengthParams.areaUnit = GeometryService.UNIT_ACRES;
areasAndLengthParams.calculationType = "geodesic";
geometryService.simplify([geometry], function (simplifiedGeometries) {
areasAndLengthParams.polygons = simplifiedGeometries;
geometryService.areasAndLengths(areasAndLengthParams);
var lengthParams = new LengthsParameters();
lengthParams.polylines = [geometry];
lengthParams.lengthUnit = GeometryService.UNIT_METER;
lengthParams.geodesic = true;
geometryServiceLength.lengths(lengthParams);
map.getLayer("drawGL").add(new Graphic(geometry, symbol));
function outputAreaAndLength(evtObj) {
var result = evtObj.result;
console.log(json.stringify(result));
dom.byId("area").innerHTML = result.areas[0].toFixed(3) + " acres";
function outputLength(evtObj) {
dom.byId("length").innerHTML = result.lengths[0].toFixed(3) + " feet";
