ESRI released its new report widget using report class, I am trying to let the report widget print my query result, which is sent from another query widget.
The data is sent from another widget uisng publishData function as an object, it is census data such as census tracts. The sending object has been tested: it is an array object containing 23 row records and each one has 57 fields as columns, e.g., 23 census tracts and each one contains fields like ID, Name, Area, Population ...
My codes inserting to the report widget is like the following, the colItem and rowItem are defined at the beginning of the report widget as colItem:null, rowItem:null,
queryResult is defined in publishData() in another widget to pass the query result as
this.publishData({
'target': 'Report',
'queryResult': this.results
My question is how to make the queryResult to display in Report widget in a good format? At least displaying as a table with fields as columns and census tracts as row records. Thanks a lot!
onReceiveData<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">,</SPAN> widgetId<SPAN class="punctuation token">,</SPAN> data<SPAN class="punctuation token">,</SPAN> historyData<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>widgetId <SPAN class="operator token">===</SPAN> <SPAN class="string token">'widgets_test_36'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Report widget got the message"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> resultItems <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> resultCount <SPAN class="operator token">=</SPAN> data<SPAN class="punctuation token">.</SPAN>queryResult<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token"><</SPAN>data<SPAN class="punctuation token">.</SPAN>queryResult<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> featureAttributes <SPAN class="operator token">=</SPAN> data<SPAN class="punctuation token">.</SPAN>queryResult<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//each row record </SPAN>
<SPAN class="comment token">//The next is to handle fields of each record and push them into resultItems</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> attr <SPAN class="keyword token">in</SPAN> featureAttributes<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
resultItems<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>featureAttributes<SPAN class="punctuation token">[</SPAN>attr<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>rowItem <SPAN class="operator token">=</SPAN> resultItems<SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>rowItem<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
_onBtnPrintClicked<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> printData <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>
addPageBreak<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>map
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Testing Report"</SPAN><SPAN class="punctuation token">,</SPAN>
addPageBreak<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"table"</SPAN><SPAN class="punctuation token">,</SPAN>
tableCols<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN>
data<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
showRowIndex<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
cols<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>colItem<SPAN class="punctuation token">,</SPAN><SPAN class="comment token">// I have no idea how to code this?</SPAN>
rows<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>rowItem
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>report<SPAN class="punctuation token">.</SPAN><SPAN class="token function">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Testing Report"</SPAN><SPAN class="punctuation token">,</SPAN> printData<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">//_onBtnPrintClicked funciton ends </SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
