I am trying to test the ArcGIS map to see if it fits the needs of my app. Unfortunately I have encountered a problem when trying to read a geodatabase created with ArcCatalog or a sample downloaded from the internet. I have tried with a developer licence and Basic license but both return the same error.
The error is:
"Unable to open the database file : "
and it it thrown on line :
Geodatabase geodatabase = await Geodatabase.OpenAsync(@{path}\db.gdb);
StackTrace:
| | StackTrace | " at RuntimeCoreNet.Interop.HandleException(Boolean retVal) at RuntimeCoreNet.CoreFeatureCache..ctor(String databasePath) at Esri.ArcGISRuntime.Data.Geodatabase..ctor(String path) at Esri.ArcGISRuntime.Data.Geodatabase.OpenAsync(String path) at SmartAssArcGISWPF.MainWindow.<MyMapView_Loaded>d__0.MoveNext() in.... | string |
Has anyone encountered the same problem and found a solution?
The licence for Developer is supposed to contain all functionality, is this one with geodatabase not included?
