So, I'm trying to make a list of items in a label. Should look like this:
Instead, its looking like this:
The arcade snippet:
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">bullet</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> isLast<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">' - '</SPAN> <SPAN class="operator token">+</SPAN> item <SPAN class="operator token">+</SPAN> <SPAN class="token function">IIF</SPAN><SPAN class="punctuation token">(</SPAN>isLast<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'\n'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">list</SPAN><SPAN class="punctuation token">(</SPAN>items<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> body <SPAN class="operator token">=</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> item <SPAN class="keyword token">in</SPAN> items<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> index <SPAN class="operator token">=</SPAN> <SPAN class="token function">IndexOf</SPAN><SPAN class="punctuation token">(</SPAN>items<SPAN class="punctuation token">,</SPAN> item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> isLast <SPAN class="operator token">=</SPAN> index <SPAN class="operator token">==</SPAN> <SPAN class="token function">Count</SPAN><SPAN class="punctuation token">(</SPAN>items<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">-</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN>
body <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> <SPAN class="token function">IIF</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">IsEmpty</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token function">bullet</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> isLast<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> body<SPAN class="punctuation token">;</SPAN>
<SPAN class="string token">'<BOL>UND>'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'test'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'</BOL></UND>\n'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="token function">list</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'hey'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'there'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>What would be the issue I'm missing?
