I have a GP service that creates a chart with matplotlib based on the lat/lon coordinates from a mouse click. The chart is saved to a folder on our web server as a .png. A link to this chart is displayed on the popup. You can right click and save or open it in another browser window. If you just click the link, it leaves the map page and opens the chart in a new browser window. There is a function in matplotlib "plt.show()" that brings up the chart in an interactive popup window with a save-to-disk and other buttons. I'd like to be able to have the chart pop up over the map and have the user be able to save it locally from the popup, if possible. I've tried window.open() but I haven't gotten it to work.
Here is my code:
<SPAN class="keyword token">var</SPAN> link <SPAN class="operator token">=</SPAN> domConstruct<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"a"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"class"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"action"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"id"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"chartLink"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"innerHTML"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Three Week Chart"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">//text that appears in the popup for the link </SPAN>
<SPAN class="string token">"href"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"javascript: void(0);"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token function">query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".actionList"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
domAttr<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"chartLink"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"innerHTML"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Generating Chart..."</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
window<SPAN class="punctuation token">.</SPAN>gp_chart <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Geoprocessor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fgis.mymetcon.com%2Farcgis%2Frest%2Fservices%2FThree_Week_Chart%2FGPServer%2FThreeWeekChart" target="_blank">http://gis.mymetcon.com/arcgis/rest/services/Three_Week_Chart/GPServer/ThreeWeekChart</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> feature <SPAN class="operator token">=</SPAN> window<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getSelectedFeature</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> mp <SPAN class="operator token">=</SPAN> webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">webMercatorToGeographic</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> x <SPAN class="operator token">=</SPAN> mp<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toFixed</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> y <SPAN class="operator token">=</SPAN> mp<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toFixed</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> lat<SPAN class="punctuation token">,</SPAN>lon <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
lat <SPAN class="operator token">=</SPAN> x<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
lon <SPAN class="operator token">=</SPAN> y<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
locationStr <SPAN class="operator token">=</SPAN> <SPAN class="token function">prompt</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Enter Location Name"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Location"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Location"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> taskParams <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"Latitude"</SPAN><SPAN class="punctuation token">:</SPAN>lat<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"Longitude"</SPAN><SPAN class="punctuation token">:</SPAN>lon<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"Location"</SPAN><SPAN class="punctuation token">:</SPAN>locationStr
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
window<SPAN class="punctuation token">.</SPAN>gp_chart<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>taskParams<SPAN class="punctuation token">,</SPAN>gpChartResultAvailable<SPAN class="punctuation token">,</SPAN>gpChartFailure<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">gpChartResultAvailable</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">,</SPAN> messages<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
domAttr<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"chartLink"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"innerHTML"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Three Week Chart"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//clear any existing features displayed in the popup </SPAN>
window<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clearFeatures</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> chart <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Three Week Chart"</SPAN>
<SPAN class="keyword token">var</SPAN> chartResult <SPAN class="operator token">=</SPAN> chart<SPAN class="punctuation token">.</SPAN><SPAN class="token function">link</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"http:/<ourserver>/Test_Charts/Three_Week_Chart_for_"</SPAN> <SPAN class="operator token">+</SPAN> locationStr <SPAN class="operator token">+</SPAN> <SPAN class="string token">".png"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//display the query results </SPAN>
<SPAN class="keyword token">var</SPAN> content <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>results <SPAN class="operator token">==</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
content <SPAN class="operator token">=</SPAN> chartResult <SPAN class="operator token">+</SPAN> <SPAN class="string token">"<br> for "</SPAN> <SPAN class="operator token">+</SPAN> locationStr<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN>
content <SPAN class="operator token">=</SPAN> <SPAN class="string token">" Unable To Generate Chart"</SPAN><SPAN class="punctuation token">;</SPAN>
window<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN>content<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
window<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>chartResult<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">chartpopup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
window<SPAN class="punctuation token">.</SPAN><SPAN class="token function">open</SPAN><SPAN class="punctuation token">(</SPAN>chartResult<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'Chart'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'height=600,width=600'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
