I am trying to use the InfoWindowChart sample that allows you to customize the info window with graphs and charts. However, when I try and use my map service the layer won't display. Can anyone help me understand what I'm doing wrong. It's probably something very simple that I'm overlooking, at least I hope that's all it is. Here is my code:<html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Info Window with Chart</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } .chart { width:200px; height:200px; padding:0px !important; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://js.arcgis.com/3.8/"></script> <script> dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.dijit.InfoWindow"); dojo.require("dojox.charting.Chart2D"); dojo.require("dojox.charting.plot2d.Pie"); dojo.require("dojox.charting.action2d.Highlight"); dojo.require("dojox.charting.action2d.MoveSlice"); dojo.require("dojox.charting.action2d.Tooltip"); dojo.require("dojo.number"); dojo.require("dijit.layout.TabContainer"); var map; //try other themes (Julie,CubanShirts, PrimaryColors, Charged, BlueDusk, Bahamation,Harmony,Shrooms) var theme = 'Wetland'; dojo.require("dojox.charting.themes." + theme); function init() { //use the info window instead of the popup var infoWindow = new esri.dijit.InfoWindow(null, dojo.create("div")); infoWindow.startup(); map = new esri.Map("map", { basemap: "streets", center: [-96, 37], infoWindow: infoWindow, zoom: 4 }); var template = new esri.InfoTemplate(); //flag icons are from http://twitter.com/thefella, released under creative commons template.setTitle("Info<b>${StoreNum}</b>"); template.setContent(getWindowContent); var storesLayer = new esri.layers.FeatureLayer("http://gis-server.greatriv.com/ArcGIS/rest/services/ShamrockMktg/StoreLocations/MapServer/0", { mode: esri.layers.FeatureLayer.MODE_SNAPSHOT, outFields: ["*"], infoTemplate: template, }); var symbol = new esri.symbol.SimpleFillSymbol(); storesLayer.setRenderer(new esri.renderer.SimpleRenderer(symbol)); map.addLayer(storesLayer); map.infoWindow.resize(275, 375); } function getWindowContent(graphic) { //make a tab container var tc = new dijit.layout.TabContainer({ style: "width:100%;height:100%;" }, dojo.create("div")); //display attribute information var cp1 = new dijit.layout.ContentPane({ title: "Details", content: "Store Number: " + graphic.attributes.STORENUM + "<br />DC: " + graphic.attributes.DC_1 + "<br />DIV: " + graphic.attributes.DIV_1 + "<br />REG: " + graphic.attributes.REG_1 + "<br />DIST: " + graphic.attributes.DIST_1 + "<br />STORE MANAGER: " + graphic.attributes.StoreManage + "<br />ADDRESS: " + graphic.attributes.Address }); //display a dojo pie chart for the male/female percentage var cp2 = new dijit.layout.ContentPane({ title: "Pie Chart" }); tc.addChild(cp1); tc.addChild(cp2); //create the chart that will display in the second tab var c = dojo.create("div", { id: "demoChart" }, dojo.create('div')); var chart = new dojox.charting.Chart2D(c); dojo.addClass(chart, 'chart'); //apply a color theme to the chart chart.setTheme(dojo.getObject("dojox.charting.themes." + theme)); chart.addPlot("default", { type: "Pie", radius: 70, htmlLabels: true }); dojo.connect(tc,'selectChild',function(tabItem){ if(tabItem.title === "Pie Chart"){ chart.resize(180,180); } }); //get percent male/female var storenum = graphic.attributes.STORENUM; var eiksalesPYTD = dojo.number.round(graphic.attributes.EIK_SALES_2012); var eiksalesYTD = dojo.number.round(graphic.attributes.EIK_SALES_2013); var eiksalesdistYTD = dojo.number.round(graphic.attributes.EIK_SALES_DA_2013); var eiksalescmpyYTD = dojo.number.round(graphic.attributes.EIK_SALES_CA_2013); chart.addSeries("Sales", [{ y: eiksalesPYTD, tooltip: eiksalesPYTD, text: 'EIK Sales 2012' }, { y: eiksalesYTD, tooltip: eiksalesYTD, text: 'EIK Sales 2013' }, { y: eiksalesdistYTD, tooltip: eiksalesdistYTD, text: 'EIK Sales Dist 2013' }, { y: eiksalescmpyYTD, tooltip: eiksalescmpyYTD, text: 'EIK Sales Cmpy 2013' }]); //highlight the chart and display tooltips when you mouse over a slice. new dojox.charting.action2d.Highlight(chart, "default"); new dojox.charting.action2d.Tooltip(chart, "default"); new dojox.charting.action2d.MoveSlice(chart, "default"); cp2.set('content', chart.node); return tc.domNode; } dojo.ready(init); </script> </head> <body class="claro"> <div id="map"></div> </body> </html>
