Hi
I add query buffer to your sample code, but the map service can not show!!.
If I remove map.addLayer(featureLayer); from code the map service load ok . please help me
<!DOCTYPE html>
<html>
<head>
<title>Display Multiple ArcGIS Online Services</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.22/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.22/esri/css/esri.css">
<style>
html,
body {
height: 97%;
width: 98%;
margin: 1%;
#map {
border: solid 1px #B5BCC7;
padding: 0;
#paneHeader {
background: url(images/header.png) repeat-x;
color: white;
border-bottom: solid 1px #B5BCC7;
text-align: center;
height: 30px;
margin: 0;
overflow: hidden;
font-size: 16px;
padding: 8px 5px;
#rightPane {
width: 150px;
margin: 0;
padding: 0;
</style>
<script src="https://js.arcgis.com/3.22/"></script>
<script>
var map;
require([
"dojo/dom", "esri/Color", "dojo/keys", "dojo/parser", "esri/config",
"esri/sniff", "esri/map", "esri/SnappingManager", "esri/dijit/Measurement",
"esri/layers/FeatureLayer", "esri/renderers/SimpleRenderer", "esri/tasks/GeometryService",
"esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol",
"esri/dijit/Scalebar",
"esri/dijit/BasemapGallery",
"esri/dijit/BasemapLayer",
"esri/dijit/Basemap",
"esri/dijit/OverviewMap",
"esri/tasks/locator",
"esri/dijit/Search",
"esri/symbols/PictureMarkerSymbol",
"esri/InfoTemplate",
"esri/dijit/HomeButton",
"esri/geometry/Extent",
"esri/SpatialReference",
"esri/dijit/VisibleScaleRangeSlider",
"esri/geometry/scaleUtils",
"esri/virtualearth/VETiledLayer",
"dijit/form/Button",
"esri/tasks/query",
"esri/geometry/Circle",
"esri/graphic",
"esri/symbols/SimpleMarkerSymbol",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/TitlePane",
"dijit/form/CheckBox",
"dojo/domReady!"
], function(
dom, Color, keys, parser, esriConfig,
has, Map,SnappingManager, Measurement,
FeatureLayer, SimpleRenderer, GeometryService,
SimpleLineSymbol, SimpleFillSymbol,
Scalebar, BasemapGallery, BasemapLayer, Basemap, OverviewMap, Locator, Search, PictureMarkerSymbol, InfoTemplate , HomeButton , Extent, SpatialReference, VisibleScaleRangeSlider, scaleUtils, VETiledLayer, Button, Query, Circle, Graphic, SimpleMarkerSymbol
parser.parse();
map = new Map("map");
var basemaps = [];
var waterTemplateLayer = new BasemapLayer({
url: "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/WaterTemplate/LocalGovernmentInfrastructureBasemap/MapServer"
var waterBasemap = new Basemap({
layers: [waterTemplateLayer],
title: "Water Template",
thumbnailUrl: "images/waterThumb.png"
basemaps.push(waterBasemap);
var publicSafetyLayer = new BasemapLayer({
url: "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyBasemap/MapServer"
var publicSafetyBasemap = new Basemap({
layers: [publicSafetyLayer],
title: "Public Safety",
thumbnailUrl: "images/safetyThumb.png"
basemaps.push(publicSafetyBasemap);
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: false,
basemaps: basemaps,
map: map
}, "basemapGallery");
basemapGallery.startup();
basemapGallery.on("error", function(error) {
console.log(error);
esriConfig.defaults.io.proxyUrl = "/proxy/";
// Add the census block points in on demand mode. An outfield is specified since it is used when calculating the total population falling within the one mile radius.
var featureLayer = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0",{
outFields: ["POP2000"]
// Selection symbol used to draw the selected census block points within the buffer polygon
var symbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CIRCLE,
12,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_NULL,
new Color([247, 34, 101, 0.9]),
new Color([207, 34, 171, 0.5])
featureLayer.setSelectionSymbol(symbol);
// Make unselected features invisible
var nullSymbol = new SimpleMarkerSymbol().setSize(0);
featureLayer.setRenderer(new SimpleRenderer(nullSymbol));
var circleSymb = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_NULL,
SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
new Color([105, 105, 105]),
), new Color([255, 255, 0, 0.25])
var circle;
// When the map is clicked create a buffer around the click point of the specified distance
map.on("click", function(evt){
circle = new Circle({
center: evt.mapPoint,
geodesic: true,
radius: 1,
radiusUnit: "esriMiles"
map.graphics.clear();
var graphic = new Graphic(circle, circleSymb);
map.graphics.add(graphic);
var query = new Query();
query.geometry = circle.getExtent();
// Use a fast bounding box query. It will only go to the server if bounding box is outside of the visible map.
featureLayer.queryFeatures(query, selectInBuffer);
function selectInBuffer(response){
var feature;
var features = response.features;
var inBuffer = [];
// Filter out features that are not actually in buffer, since we got all points in the buffer's bounding box
for (var i = 0; i < features.length; i++) {
feature = features;
if(circle.contains(feature.geometry)){
inBuffer.push(feature.attributes[featureLayer.objectIdField]);
query.objectIds = inBuffer;
// Use an objectIds selection query (should not need to go to the server)
featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){
var totalPopulation = sumPopulation(results);
var r = "";
r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>";
dom.byId("messages").innerHTML = r;
function sumPopulation(features) {
var popTotal = 0;
for (var x = 0; x < features.length; x++) {
popTotal = popTotal + features.attributes["POP2000"];
return popTotal;
</script>
</head>
<body class="claro">
<span id="messages">Click on the map to select census block points within 1 mile.</span>
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width:100%;height:100%;">
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
</div>
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'" id="rightPane">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;">
<div id="paneHeader" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
<span>Select Basemap</span>
</div>
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
<div id="basemapGallery"></div>
</div>
</div>
</div>
</div>
</body>
</html>
