I am relatively new to Quick Capture. I set up a test project for point data to be collected in the field with associated pictures and comments. My goal is to export the data as a shapefile for storage, and use in ArcMap 10.1. All of the desired attributes come over with the data (including attributes setup in the hosted feature layer and the Quick Capture Designer) but the picture associated with each point does not. Is there an easy way to send those pictures over to the shapefile with the other attributes without having to open/ save each picture and then manually associate each picture with the respective point?
Clint
