While trying to add a feature service widget that is partly based off of [HTML]http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/#sample/ed_default_editingwidget[/HTML]and partly based off of an existing page. While the feature layers do appear in the toolbar/content pane. I currently am getting an error when I try to do the doubleclick that sends the information to the serverI beleive this results from incorrect input parameters being sent due to this page:[HTML]http://resources.arcgis.com/en/help/main/10.1/index.html#/Task_operation_execute_REST/0057000000m5000000/[/HTML]The form data sends is :f:json
adds:[{"geometry":{"rings":[[[-9163974.606536975,4639277.6829617545],[-9156961.509191819,4634863.444578291],[-9166363.263670884,4627678.363919495],[-9166879.213611808,4640099.381015819],[-9163974.606536975,4639277.6829617545]]],"spatialReference":{"wkid":102100}},"attributes":{"PROBKEY":"SP","COMMENTS":null,"PADNUMBER":null,"PADNAME":null,"AREA_":null,"DEPTH":null,"VOLUME":null,"STATUS":null,"UPDATEDBY":null,"DATEUPDATED":null}}]
Here is the code which may be responsible for the error: function initEditor(results) {
var templateLayers = dojo.map(results,function(result){
return result.layer;
var templatePicker = new esri.dijit.editing.TemplatePicker({featureLayers: templateLayers,
rows: "auto",
columns: 3
},'editingDiv');
templatePicker.startup();
var layerInfos = dojo.map(results, function(result) {
return {'featureLayer':result.layer};
var settings = {
map: map,
geometryService: new esri.tasks.GeometryService("/arcgis/rest/services/Utilities/Geometry/GeometryServer"),
templatePicker: templatePicker,
layerInfos: layerInfos,
var params = {
settings: settings
editorWidget = new esri.dijit.editing.Editor(params);
var options = {snapKey:dojo.keys.copyKey};
map.enableSnapping(options);
editorWidget.startup();
The error is below.Error {code: 400, message: "Unable to complete operation.", details: Array[0], log: undefined}
_ssl: undefined
arguments: undefined
code: 400
details: Array[0]
get stack: function () { [native code] }
log: undefined
set stack: function () { [native code] }
type: undefined
__proto__: d
serverapi.arcgisonline.com:15
_48f serverapi.arcgisonline.com:15
(anonymous function) serverapi.arcgisonline.com:15
_1e1 serverapi.arcgisonline.com:15
_1df serverapi.arcgisonline.com:15
resolve.callback serverapi.arcgisonline.com:15
rDfd.then.otherwise._49d.error serverapi.arcgisonline.com:15
_4b9 serverapi.arcgisonline.com:15
_4b3 serverapi.arcgisonline.com:15
resolve serverapi.arcgisonline.com:15
_4c0 serverapi.arcgisonline.com:15
_3dd serverapi.arcgisonline.com:15
_3e9 serverapi.arcgisonline.com:15
and the code in the init that is related to the init editordojo.connect(map, "onLayersAddResult", initEditor);
var operationsPointLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/0", {
mode: esri.layers.FeatureLayer.MODE_SELECTION,
outFields: ["*"]
var operationsLineLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/1", {
outFields: ["*"],
var operationsPolygonLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/2", {
outFields: ["*"],
var operationsProblemsLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/3", {
outFields: ["*"],
map.addLayers([operationsPointLayer, operationsPolygonLayer, operationsLineLayer,operationsProblemsLayer]);
I am pretty confident that something needs to be tweaked in initeditor. I just am not sure what at this point
