Hello Community,
since the beginning of my work with Flex as well as with the new WebAppBuilder i have a problem with the representation of postal codes / ZIP code within the PopUp.
My shapefile was created within ArcGIS. I had points and joined some information to them. The information from an external table also included Postal Codes. After the table join everything looks fine in ArcGIS.
An Example: Postal Code as shown and stored within my shp-file: 91126
Now my problem:
Within Flex Viewer as well as within the WAB my postal code is reformated:
Within Flex the example Postal Code changes to: 91.126 (the option to use 1000-seperator within the pop up configurator is off)
Within WAB the example Postal Code changes to: 91.126,00
Where can i define the representation of fields including a number? I do not want to change the field in a string field.
Does anyone have any experience and maybe a solution to the shown problem?
Best regards and thank you in advice,
Thomas
