I'm trying to set up alerts in GeoEvent Processor, which have the following conditions:
- My input is a table with data concerning water pressure, has the following fields: ROWID, DATE, VALUE, CODSIG.
- The output is a feature class which updates the DATE and VALUE fields.
My problem is defining alerts, because for each point alerts will be different.
Need to define a condition for the maximum pressure and one for the minimum water pressure, but using fields (the output feature) that have already set these values of minimum and maximum pressure.
You can do this kind of Alert?
It can even be something simple, but only started working with the GEP this week.
Thank you for your help.
best regards
José Costa
