Hello;
I have developed a WAB application with the Direction widget. The route web service has 2 travel modes.
In the startupt function of the widget I set the travel mode to one of them (not the default ) and initialize the Direction dijit:
var routeTask = new RouteTask(this.config.routeTaskUrl1);
routeTask.getServiceDescription().then(lang.hitch(this, function (serviceInfo) {
travelModes=serviceInfo.supportedTravelModes;
this._dijitDirections.routeParams.travelMode= travelModes[1];
this._dijitDirections = new Directions(options, directionContainer);
this._dijitDirections.startup();
After the line: this._dijitDirections.startup (); the property travelMode is correct because it has the value that I have previously assigned: travelModes [1].
But when the calculation of the route starts, the travelMode property changes to the other travel mode (travelModes [0]) and the calculation is made with this other travel mode.
I can see it in the directionStart event with the debugging tools.
Any suggestions about how to make the calculation with the travel mode that I configured at the start (this._dijitDirections.routeParams.travelMode = travelModes [1];).?
the combo always shows the travel mode that I do not want.
Js api version 3.22
Thank you very much.
