i want to add shapefile to the map from the folder. i have used JS sample code but it does not work for me. It gives error in response , featurecollection. It does not get into request block so i change it to esri request but still code not working. TypeError: Cannot read property 'layers' of undefined
<SPAN class="keyword token">var</SPAN> portalUrl <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fwww.arcgis.com" target="_blank">https://www.arcgis.com</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN>
esriConfig<SPAN class="punctuation token">.</SPAN>defaults<SPAN class="punctuation token">.</SPAN>io<SPAN class="punctuation token">.</SPAN>proxyUrl <SPAN class="operator token">=</SPAN> <SPAN class="string token">"/proxy/"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"uploadForm"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"change"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> fileName <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>target<SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toLowerCase</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token function">sniff</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ie"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//filename is full path in IE so extract the file name --></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN> <SPAN class="keyword token">var</SPAN> arr <SPAN class="operator token">=</SPAN> fileName<SPAN class="punctuation token">.</SPAN><SPAN class="token function">split</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\\"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN> fileName <SPAN class="operator token">=</SPAN> arr<SPAN class="punctuation token">[</SPAN>arr<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">-</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>fileName<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".zip"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">!==</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//is file a zip - if not notify user</SPAN>
<SPAN class="token function">generateFeatureCollection</SPAN><SPAN class="punctuation token">(</SPAN>fileName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">alert</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Add shapefile as .zip file"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> generateFeatureCollection <SPAN class="punctuation token">(</SPAN>fileName<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> name <SPAN class="operator token">=</SPAN> fileName<SPAN class="punctuation token">.</SPAN><SPAN class="token function">split</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"."</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
name <SPAN class="operator token">=</SPAN> name<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"c:\\fakepath\\"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> params <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">'name'</SPAN><SPAN class="punctuation token">:</SPAN> name<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'targetSR'</SPAN><SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'maxRecordCount'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1000</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'enforceInputFileSizeLimit'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'enforceOutputJsonSizeLimit'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//var extent = scaleUtils.getExtentForScale(map, 40000);</SPAN>
<SPAN class="keyword token">var</SPAN> extent <SPAN class="operator token">=</SPAN> esri<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getExtentForScale</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">40000</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> resolution <SPAN class="operator token">=</SPAN> extent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getWidth</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">/</SPAN> map<SPAN class="punctuation token">.</SPAN>width<SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>generalize <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>maxAllowableOffset <SPAN class="operator token">=</SPAN> resolution<SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>reducePrecision <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>numberOfDigitsAfterDecimal <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> myContent <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">'filetype'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'shapefile'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'publishParameters'</SPAN><SPAN class="punctuation token">:</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stringify</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'f'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'json'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">//'callback.html': 'textarea'</SPAN>
<SPAN class="token function">esriRequest</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> portalUrl <SPAN class="operator token">+</SPAN> <SPAN class="string token">'/sharing/rest/content/features/generate'</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> myContent<SPAN class="punctuation token">,</SPAN>
form<SPAN class="punctuation token">:</SPAN> dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'uploadForm'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
handleAs<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'json'</SPAN><SPAN class="punctuation token">,</SPAN>
load<SPAN class="punctuation token">:</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">.</SPAN>error<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN> <SPAN class="token function">errorHandler</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">.</SPAN>error<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN><SPAN class="operator token">--</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token">--</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">var</SPAN> layerName <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>FeatureCollection<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>layerDefinition<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">addShapefileToMap</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">.</SPAN>FeatureCollection<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">//error: lang.hitch(this, errorHandler)</SPAN>
<SPAN class="keyword token">function</SPAN> addShapefileToMap <SPAN class="punctuation token">(</SPAN>featureCollection<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> fullExtent<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> layers <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
arrayUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>featureCollection<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Details"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"${*}"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> featureLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
infoTemplate<SPAN class="punctuation token">:</SPAN> infoTemplate
featureLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'click'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setFeatures</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>event<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">changeRenderer</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
fullExtent <SPAN class="operator token">=</SPAN> fullExtent <SPAN class="operator token">?</SPAN>
fullExtent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">union</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">.</SPAN>fullExtent<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">:</SPAN> featureLayer<SPAN class="punctuation token">.</SPAN>fullExtent<SPAN class="punctuation token">;</SPAN>
layers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayers</SPAN><SPAN class="punctuation token">(</SPAN>layers<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setExtent</SPAN><SPAN class="punctuation token">(</SPAN>fullExtent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">expand</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1.25</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> changeRenderer <SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//change the default symbol for the feature collection for polygons and points</SPAN>
<SPAN class="keyword token">var</SPAN> symbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">switch</SPAN> <SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">.</SPAN>geometryType<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">'esriGeometryPoint'</SPAN><SPAN class="punctuation token">:</SPAN>
symbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PictureMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">'angle'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'xoffset'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'yoffset'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'type'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'esriPMS'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'url'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fstatic.arcgis.com%2Fimages%2FSymbols%2FShapes%2FBluePin1LargeB.png" target="_blank">https://static.arcgis.com/images/Symbols/Shapes/BluePin1LargeB.png</A><SPAN>'</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'contentType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'image/png'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'width'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">20</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'height'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">20</SPAN>
<SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">'esriGeometryPolygon'</SPAN><SPAN class="punctuation token">:</SPAN>
symbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>
SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">112</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">112</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">112</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">136</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">136</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">136</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>symbol<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
layer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN>symbol<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
