I am using the latest version of the ESRI JavaScript API to build a basemap template.
What I would like to do is pass an address parameter into my map so that when it opens the map is zoomed into the address in question. I am currently doing this with the Viewer for Flex using the following code:
Viewer for Flex: (link not active) http://myserver.com/flexviewers/actmap/index.html?search=15 Fordham St, Pocatello, Idaho
I came across this example for ArcGIS Online:
http://www.arcgis.com/home/webmap/viewer.html?find=380 new york st,redlands,ca
How do I do this with the JavaScript API for ESRI ArcGIS?
Do I need to define parameters within the code or can I simply pass URL parameters to the map like in the above examples to the geocode or locator widgets?
Thanks in advance,
