System ArcGIS 9.3ProblemI tried to project using shorthand of 1984 prj.However, it failed and said ERROR 999999: Error executing function.A locator with this name does not exist.Failed to execute (Project).Please kindly explain the error cause and advise any modification in need of the code below.Thanks a lot.##Script Name: Project shapefiles (batch) ##Description: project multiple shapefiles ##Created By: Elaine Kuo ##Date: 08/05/2012 #Import standard library modules import arcgisscripting import os #Create the Geoprocessor object gp = arcgisscripting.create(9.3) #Set the input workspace #GP.workspace = sys.argv[1] #Set the workspace. gp.Workspace= "H:/temp/test1" #Set the output workspace #outWorkspace = sys.argv[2] #Set the workspace. List all of the feature classes in the dataset outWorkspace= "H:/temp" # Set the spatial reference variable cs = "C:/Program Files/ArcGIS/Coordinate Systems/Geographic Coordinate Systems/World/WGS 1984.prj" #Get a list of the featureclasses in the input folder fcs = gp.ListFeatureClasses() # Loop through every item in the list that was just generated for fc in fcs: # Break out the name, no path or extension, using the describe object. desc = gp.describe(fc) featureName = desc.name # Make featureclasses as layers outFeatureClass = outWorkspace + os.sep + gp.ValidateTableName(featureName, outWorkspace) gp.Toolbox = "management" gp.Project(fc, outFeatureClass, cs)
