I am using this ArcGIS Runtime SDK for .NET Code Sample code to show a GeoTIFF file on my map. Some parts of my GeoTIFF file does not include any image and should display transparent.
The SDK shows the GeoTIFF file on map fine except the fact that the area that should display transparent are showing black, and users cannot see what is on the underneath map.
Is there any way to tell the SDK to show the GeoTIFF background transparent instead of black?
Currently there is no API feature for specifying the transparent pixel value, but you could try applying a mask function via a JSON definition:
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"raster_function"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"Mask_function"</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"raster_function_arguments"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"nodata_values"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">"double_array"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN>value1<SPAN class="punctuation token">,</SPAN> value2<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">,</SPAN> valueN<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"Raster_function_variable"</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"nodata_interpretation"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">"nodata_interpretation"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"all"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"Raster_function_variable"</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"raster"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">"name"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"raster"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"is_raster"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"Raster_function_variable"</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"Raster_function_arguments"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"Raster_function_template"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Shown in sample: arcgis-runtime-samples-dotnet/RasterLayerRasterFunction.xaml.cs at master · Esri/arcgis-runtime-samples-dotnet · GitHub
Cheers
Mike
Přihlášení členové mohou přispívat, sledovat aktualizace a další. Jste tu noví? Zaregistrujte si bezplatný účet.
